Home > Technical (L322) > Restricted performance on deceleration - P0107 |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
What supply voltage are you getting at the MAP sensor? - measure at the sensor wiring across the +ve & -ve, should be in the range of 4.75 - 5.25VDC |
14th Jun 2022 5:34pm |
Warminster 201289 Member Since: 13 Sep 2021 Location: Bristol Posts: 6 |
Just tested and measuring 4.9v at supply and have continuity at ground. |
14th Jun 2022 6:18pm |
Is this a 3.6 or a 4.4 TDV8? |
14th Jun 2022 6:48pm |
Sorry, it’s the 4.4TDV8. |
14th Jun 2022 6:50pm |
Assuming no intake leaks, blocked air filters, charge air leaks etc. I'd be looking for delaminating hoses creating a restriction on deceleration. As always, a smoke test would be the preferred first step but obviously not everyone can do that.
14th Jun 2022 7:13pm |
No obvious leaks and I’ve replaced the filters (hoping this was the reason) but not thought about delam pipes!
14th Jun 2022 7:24pm |
They usually occur on bends rather than straight-ish sections, look for discolouration on the outside where oil is penetrating and feel for any weaker areas when poked and prodded, an endoscope is invaluable for looking inside for bubbles and tears and can be found quite cheaply on fleabay to connect to your phone or PC. - it will be something simple that's causing it, finding it is the hard part, good luck! |
14th Jun 2022 7:53pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3143 |
take it down to Steve at T and S Norman in Shepton mallet. What he don't know about the L322 doesn't need knowing. He fixed my RP prob by engineering nouse, after all the LR dealers and specialists failed. pm me for details if you can't find them on t'internet |
14th Jun 2022 8:48pm |
