Home > Technical (L322) > Aircon problem
Page 2 of 3 <123>
Phoenix
I'm sure that if you really had 40Bar in the system, something would have burst by now!
Post #634469 12th Jun 2022 8:17pm
Paddocks67
Would a faulty switch give that reading on the gap iid tool
Post #634472 12th Jun 2022 8:23pm
Phoenix
Never used a GAP iiD so couldn't say - a faulty pressure transducer can give any kind of spurious readings - as can shorted or corroded wiring, the first check given that 40Bar is improbable is to disconnect the sensor and see what changes.
Post #634473 12th Jun 2022 8:27pm
Paddocks67
Thanks for the replies,I will do that tomorrow night and see what happens.cheers pat
Post #634474 12th Jun 2022 8:32pm
Paddocks67
Hi lads,I took the low pressure switch connection off,to see if it gave me any other codes on the gap iid tool,and it just said the same fault,refrigerant pressure fault,so it looks like faulty low pressure switch could be the problem,what do youse think,cheers pat
Post #634556 13th Jun 2022 8:08pm
Phoenix
What value is being reported? still 40Bar?
Post #634559 13th Jun 2022 8:41pm
Paddocks67
Yes still says 40 bar on iid tool
Post #634561 13th Jun 2022 10:20pm
Phoenix
It does sound like the pressure sensor has an internal defect, obviously you'll need to recover the refrigerant before replacing it.
Post #634566 14th Jun 2022 6:11am
Paddocks67
Hi lads,I got a replacement sensor,but when I was taking my sensor off,it snapped off,now I need a new pipe,how hard is it to replace the whole pipe.and are there different pipes for tdv8 and td6,cheers pat
Post #634942 18th Jun 2022 2:39pm
Phoenix
Looks like there's one pipe fits all - JUE500560 Get Duckworths to check against your VIN though, it goes to the evaporator with a flexi bit on the other end, comes with sensor & seals, shouldn't be too bad to fit as long as the bolts haven't corroded in....
ETA - looks like there's a different one for 7A VIN's, again, get Duckworths to check your VIN.
Post #634959 18th Jun 2022 5:31pm
Paddocks67
Hi lads,have just got a replacement pipe from scrappies,but there seems to be a slight difference as it doesn't have a valve on it,would it still be ok to use or do I need one with a valve,as you only fill refrigerant using the low pressure valve,would it make any difference,cheers pat
Post #635465 25th Jun 2022 9:02pm
Phoenix
You can fill refrigerant with the HP or LP port - or both, it makes no difference.
Post #635467 25th Jun 2022 9:09pm
Paddocks67
Hi Phoenix,do you need the high side valve on the pipe,the pipe I have doesn't have it,will it still work
Post #635470 25th Jun 2022 9:40pm
Paddocks67
Post #635471 25th Jun 2022 9:52pm
Phoenix
Yep, it'll work fine mate, it's perfectly acceptable to vac and charge the system via one port (and some systems only have a low side port), it's useful to have both ports for pressure measurements if diagnostic checks need to be carried out but you can access the pressure transducer readings for the high side if needed.
Post #635483 26th Jun 2022 7:55am
Page 2 of 3 <123>
