Home > Maintenance & Mods (L322) > Replacement / recon engine needed... |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
Is the engine running “ok”? 2011 Range Rover Vogue SE 4.4 TDV8
7th Jun 2022 2:06pm |
Mistercorn Member Since: 01 Feb 2014 Location: Nottingham Posts: 109 |
It was running. I started it and saw a 'low coolant warning' On checking the coolant I saw oil around the coolant tank and when I took the lid off more oil came out. I then started and ran the car to get it on the trailer to have it removed.
7th Jun 2022 2:08pm |
That is what happens when the oil cooler issue gets ignored.
7th Jun 2022 2:18pm |
7th Jun 2022 2:30pm |
He did say when I dropped it off that it could be the oil cooler or it could be something more serious on the engine, and he is saying that it is the engine. I have asked for confirmation that he has removed and tested the oil cooler though as it did look similar to that.
7th Jun 2022 2:52pm |
I’d want a bit more info than that, as you say. If it was driving fine, I can’t see it being engine. The oil cooler is a heat exchanger and passes the coolant next to the oil. They mix when the seal goes or the oil cooler warps…. Oil is a pretty good coolant, so you prob won’t notice anything in the short term.
7th Jun 2022 3:02pm |
Not seen oil in the coolantl before, car is on 115k and I've owned it since 49k. Oil heat exchanger hasn't been changed in that time. It was last in the garage a few months ago for a new water pump.
7th Jun 2022 3:06pm |
Caught it in time then I’d say….
7th Jun 2022 3:13pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Agree with MJ! I'd put money on it being the oil cooler gaskets. I suspect your mechanic is either not up to speed with these engines, or is potentially trying to pull a fast one..... The older I get, the more I realise that people confuse wrinkles for wisdom |
7th Jun 2022 4:41pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
Oil in the coolant is not a terminal condition. The oil runs at higher pressure than the coolant so highly unlikely coolant has got into the oil. Take off the oil filler cap and check for 'mayonaise' Nearly everyone here with a TDV8 4.4 will have had or done an oil cooler seal replacement. 2012 TDV8 Vogue (L322) |
7th Jun 2022 5:18pm |
The cooler itself can warp or crack too. I’d change that and the seals. No need to worry about it then…
7th Jun 2022 5:28pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
When my heat exchanger went on mine it took JLR three days to get the oil flushed out of the system, I think it cost me around £800 should be less from an Indie |
7th Jun 2022 5:39pm |
He did say the engine isn't OK. I'll get more details tomorrow. He only works on Range Rovers and Land Rovers so he does know them extremely well.
7th Jun 2022 6:27pm |
See what he says tomorrow then.
7th Jun 2022 7:01pm |
