Home > Technical (L322) > Stinking |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3763 |
Try carefully touching each rear wheel, just in case the brake calipers are sticking.
19th Apr 2022 4:28pm |
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 234 |
Perhaps I should add it’s a 4.4tdv8. |
19th Apr 2022 4:29pm |
Mike, both rear wheels are certainly colder than the fronts. |
19th Apr 2022 4:31pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3188 |
What kind of smell is it? ( front brakes hotter than rear is good) 2012 TDV8 Vogue (L322) |
19th Apr 2022 4:55pm |
It’s certainly coming from under the bonnet area. |
19th Apr 2022 4:59pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
Mine had a tiny leak from the top hose to thermostat housing which led to a very sweet hot smell. No smell since I changed the hose. |
19th Apr 2022 5:30pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Has it had the oil cooler gaskets and o-rings done? The older I get, the more I realise that people confuse wrinkles for wisdom |
19th Apr 2022 9:02pm |
Still need to hear from the OP the nature of the smell...... 2012 TDV8 Vogue (L322) |
20th Apr 2022 5:23am |
Well after completing the same climb back up to our accommodation this evening I decided to use the flappy paddles to keep the revs down slightly. It seems that the RR likes to hold onto 3rd a little longer than I think it ought too. The result was a much less smelly engine once back at our accommodation. Figure that out… |
20th Apr 2022 7:03pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2575 |
If it hasn't been done then I am with oil cooler |
20th Apr 2022 7:16pm |
That seems to make sense. Is it a DIY job or send it off to the Indy? |
20th Apr 2022 7:44pm |
Davlyn, have a look at the wiki, if you are handy with the spanners seems straight forward, I am not so had it done, |
20th Apr 2022 8:01pm |
Depends what kind of smell it is..... 2012 TDV8 Vogue (L322) |
21st Apr 2022 7:59am |
BTW your car seems to be a 2015 L405? This sub section is for the earlier L322. 2012 TDV8 Vogue (L322) |
21st Apr 2022 8:05am |
