Home > Technical (L322) > Stinking
Page 1 of 3 123>
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Stinking
All, we are currently in the Lake District on our Hols. RR seems to be okay other than the climb up to where we are staying is leaving the ol’ girl stinking once we get to our accommodation. It’s probably a good 2 mile climb up some very narrow windy roads, all at speeds ranging from walking pace to about 20mph max.
The temp gauge seems to stay smack bang in the middle and I’m getting no warning lights on, however it just smells really hot. After having a quick peer under the bonnet nothings seems to be a miss.
My daughters with us in her VW T-Roc and that doesn’t seem to smell at all after the same climb.
Any thoughts?
Post #629102 19th Apr 2022 4:22pm
Baltic Blue
Try carefully touching each rear wheel, just in case the brake calipers are sticking.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #629104 19th Apr 2022 4:28pm
Davlyn
Perhaps I should add it’s a 4.4tdv8.
Post #629105 19th Apr 2022 4:29pm
Davlyn
Mike, both rear wheels are certainly colder than the fronts.
Post #629106 19th Apr 2022 4:31pm
JayGee
What kind of smell is it? ( front brakes hotter than rear is good) 2012 TDV8 Vogue (L322)
Post #629115 19th Apr 2022 4:55pm
Davlyn
It’s certainly coming from under the bonnet area.
Post #629116 19th Apr 2022 4:59pm
kevinp
Mine had a tiny leak from the top hose to thermostat housing which led to a very sweet hot smell. No smell since I changed the hose.
Post #629127 19th Apr 2022 5:30pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Has it had the oil cooler gaskets and o-rings done? The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #629166 19th Apr 2022 9:02pm
JayGee
Still need to hear from the OP the nature of the smell...... 2012 TDV8 Vogue (L322)
Post #629177 20th Apr 2022 5:23am
Davlyn
Well after completing the same climb back up to our accommodation this evening I decided to use the flappy paddles to keep the revs down slightly. It seems that the RR likes to hold onto 3rd a little longer than I think it ought too. The result was a much less smelly engine once back at our accommodation. Figure that out…
Post #629251 20th Apr 2022 7:03pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
If it hasn't been done then I am with oil cooler Thumbs Up
Post #629252 20th Apr 2022 7:16pm
Davlyn
That seems to make sense. Is it a DIY job or send it off to the Indy?
Post #629259 20th Apr 2022 7:44pm
Rosco
Davlyn, have a look at the wiki, if you are handy with the spanners seems straight forward, I am not so had it done, Thumbs Up
Post #629262 20th Apr 2022 8:01pm
JayGee
Depends what kind of smell it is..... 2012 TDV8 Vogue (L322)
Post #629281 21st Apr 2022 7:59am
JayGee
BTW your car seems to be a 2015 L405? This sub section is for the earlier L322. 2012 TDV8 Vogue (L322)
Post #629282 21st Apr 2022 8:05am
Page 1 of 3 123>
