Home > Technical (L322) > Fault Code
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Fault Code
Hi all
Couple of months ago I had to change the surround camera module, so far so good.
I recently was going thru the fault codes because one of the front cameras is not working anymore and the other one is sending the picture upside down. Found the problem in a broken wire loom. Actually, it was squeezed between the bumper and the steel guard behind as I had a little accident. Whistle
One Fault code is referring to this missing camera but the second one is the one who gives me a headache;
-U201A-51 (2F) Control module main calibration data - System programming failure - not programmed
How can this module be programed? Is this something I can do with the IID-Tool or do I need to see the stealer?
Before the Wire loom broke all cameras were working properly.
Any tips will be welcome.
Have a nice Friday evening.
Andy
Post #627539 1st Apr 2022 2:48pm
