Home > Technical (L322) > Seat squab swap? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2214 |
Also my heating cooling is great so was going to recycle the ducts just wondered if it’s worth changing the foam topper or if it’s so thin it’s doesn’t make much difference anyway Current stable:
27th Feb 2022 12:40am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16230 |
Yes you can put the drivers seat base in the passenger side... You will however need to remove the passengers weight switch and re install it in the new passenger seat swab sir... |
27th Feb 2022 12:50am |
Cheers I will likely get new bases and swap Current stable:
27th Feb 2022 1:02am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1523 |
I must be old. When I was growing up, the squab (British English) was the seat backrest and one sat on the cushion.
27th Feb 2022 3:06am |
