Home > Maintenance & Mods (L322) > 4.4 tdv8 intake manifold plenum change |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 773 |
Having just replaced the oil cooler gaskets on New Years Day, removal of the inlet plenum was the first part of the job and I have to say it was a lot easier than you describe.
5th Jan 2022 5:34pm |
klj Member Since: 24 Aug 2019 Location: Frozen North Posts: 66 |
Hi . Thanks for the info. Glad yours was snafu free I take it you had no issues with those four studs / bolts ?
5th Jan 2022 6:39pm |
I never removed the metal throttle body from the plastic.... The older I get, the more I realise that people confuse wrinkles for wisdom |
5th Jan 2022 7:07pm |
cheers ----------------
5th Jan 2022 8:01pm |
Hi all. The studs are shown here as HT1. There are 4. Cheers
5th Jan 2022 10:46pm |
I think the studs you're talking about are the two which secure the long black plastic 'blobs' which hold the front of the engine cover. They have inverted Torx heads on them, but I actually used a std 4mm socket (1/4") to get them off and they weren't particularly tight - circa 10Nm.
5th Jan 2022 11:56pm |
Cheers once again. Those torx ended studs are the issue . But no longer ----------------
6th Jan 2022 8:07am |
BIG Benny Member Since: 27 Mar 2023 Location: North Yorkshire Posts: 1 |
Ive just done this, I undid the screws/bolts underneath that bracket that's held on by the studs, X3 10mm going up into the plenum. |
19th Apr 2023 9:01pm |
