Home > Technical (L322) > L322 Key Turn does not crank |
paddylimbo Member Since: 08 Apr 2021 Location: SHeffield Posts: 6 |
HI
21st Dec 2021 4:25pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35278 |
battery or loose connection to the battery? ... - .- -.
21st Dec 2021 4:39pm |
We have checkesd the battery and the RAC man checked it a couple of times we he looked at it so don't believe it is that, we have had it off and on since fitting the ne module as well, and doble checked it. |
21st Dec 2021 4:57pm |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 |
Another possible could be the gear selector inhibitor switch telling the ecu the car is in gear rather than park or neutral thereby preventing the starter motor operating. see thread here https://www.fullfatrr.com/forum/topic15665...r+selector |
21st Dec 2021 7:01pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
@NobbyC: yes, good point but I changed my XYZ switch and it made no difference. The car did think it was stuck in 3rd but soon cleared when the ignition switch button was installed. |
21st Dec 2021 8:50pm |
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 54 |
Agree with potential inhibitor switch. I had that on a P38 years ago. You could try dropping it out of park and into neutral before cranking. L405 2017 TDV6 AB
21st Dec 2021 8:52pm |
Thanks Matt, tried it in neutral but no joy. so frustrating. |
22nd Dec 2021 9:11am |
Winkelried Member Since: 14 Aug 2016 Location: UR Posts: 7 |
I've had this issue several times. Mostly its low voltage or a battery on its last legs.
2nd Jan 2022 2:04pm |
thanks for that will have another try with the battery off. |
4th Jan 2022 3:03pm |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 187 |
I had exactly the same symptoms not that long ago, removed the xyz switch, cleaned out the inside and bent the wire pins so they were making better contact then put it all back together and haven't had a single problem with starting since. |
4th Jan 2022 3:55pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
You can replace the ignition switch not do hard I did that on mine but it was the starter motor in the end.
4th Jan 2022 5:22pm |
