Home > Technical (L322) > Window anti trap issue but only when it's cold |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
Hi All,
14th Dec 2021 3:00pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2256 |
Gummi Pflege is the answer its about a fiver |
16th Dec 2021 8:14am |
I've got done of that somewhere. Will give it a try.
16th Dec 2021 9:18am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
Mine does that when I try to close the window at 70mph. I have to slow down to 60mph before it will close. Obviously my window is being 'sucked out' with the speed of the car so I wonder if your window channels have swelled a bit, pinching the window. Can you get a wide blade screwdriver and make sure there aren't any tight spots in the window channel? |
16th Dec 2021 10:06am |
Good idea. I'll give it a try. 2010 4.4 TDV8 Vogue SE |
16th Dec 2021 10:33am |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 451 |
I have the same issue on my 2018 Mercedes, it seems to get damp in the inside, and only starts working when it drys out |
16th Dec 2021 3:38pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Silicone spray down the channels for sure... |
16th Dec 2021 11:54pm |
Just a quick follow up for this, the silicone spray appears to have totally fixed this. I was sure it was a mechanical issue but clearly not!
20th Feb 2022 12:07am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7790 |
Mine still does this, only when very cold. Think the window rubber is less compliant, I put light pressure on top corner of the glass when it’s going in the last nit. Fine for ages then. Just that you have to stop driving to do it 🤣.
20th Feb 2022 12:41pm |
