Home > Technical (L322) > Electric thermostat circuit fault ***solved*** |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
M62 engine.
5th Nov 2021 7:50pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8223 |
Lots of info here, shows what a waste of time it is to keep it, does your engine no good at all...!!
5th Nov 2021 8:43pm |
Thanks one more time, Pete. I'm aware of the mod and may in fact go for it eventually if this is proven to be the thermostat. I do prefer to keep my car in stock configuration but this mod indeed has its merits. |
5th Nov 2021 8:48pm |
The ONLY reason for the stock excessive heat was to pass emissions, nothing else, BMW never ran the engine that hot...!! Pete
5th Nov 2021 9:47pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1529 |
I've done the mod. I'd like to knoiw what resistance I need to connect to the wiring to emulate the heater element and thus get rid of the fault code. Ron B. VK2OTC
6th Nov 2021 3:34am |
Pleased to report that the issue has apparently been resolved. Disconnected the plug once again, soaked it in WD40 and gently pushed / bent inwards the metallic terminals on the plug to achieve a tighter fit. Squirted some more WD40 on the thermostat terminals as well.
6th Nov 2021 6:13pm |
