Home > Technical (L322) > Brembo pad retention pins
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
A common issue, the pins holding in the brake pads were seized in place.
One side came out fine, the other was solid. After repeated blows with a punch and club hammer, the pin ended up bent.
I had to use a Dremel to cut the pins in half and drift the halves out individually.
What they should look like:
What they ended up looking like:
The tools needed to remove them:
Post #608754 9th Oct 2021 9:31pm
Mike220
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Yes I feel your pain, I was there myself earlier in the year. An air chisel with a pointed tip also works if you have one, the number of impacts per minute/second is unmatched and felt far kinda to the caliper body than hammer and punch blows
Bloody daft design, and yes the pins were made of chocolate Laughing 2011 Vogue SE Tdv8 FFRR
Post #608755 9th Oct 2021 10:21pm
A common problem, I always take the pads out, clean it all up and regrease the pins during routine servicing, keeps them free... Thumbs Up Pete
Post #608756 9th Oct 2021 10:22pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Yeah, stupid design!
Needs a 4lb lump hammer and they surrender readily with a few reasonable taps. No need to batter the hell out of anything, as happens with a lesser tool. Don't ask me how I know this!
Ceramic grease on reassembly
Chris
Post #608806 10th Oct 2021 5:22pm
Caesium
This is the grease I use. This is the grease you’re supposed to use on an alloy calliper.
Post #608811 10th Oct 2021 6:36pm
