Home > Technical (L322) > Parking Sensor
Growl
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Orkney Grey
Parking Sensor
Hi all, any thoughts appreciated. My parking distance sensor isn't working on a FF 4.4 AB 2012 L322, I have had a sensor replaced and have tried 3 different modules in it but no joy, vehicle shows no faults, there is a long been when engaging reverse, camera and everything else seems fine, bloody frustrating
Post #608499 6th Oct 2021 5:25pm
Growl
Sorry 'been' should read 'beeb' bloody auto correct
Post #608500 6th Oct 2021 5:27pm
Growl
This is my module
Post #608505 6th Oct 2021 6:02pm
Growl
This, sorry
Post #608507 6th Oct 2021 6:02pm
Chris1573
I had issue with sensors when I got my FF. It turned out the sensors were all fine but the wiring that runs to them had been trapped and was damaged. Probably when the bumper had been removed previously. If you pull the bumper off and check the wiring I would hazard a bet that you will find a break. L322 2007 TDV8 3.6
Post #608540 7th Oct 2021 8:10am
Growl
Brilliant, thank you
Post #608545 7th Oct 2021 8:51am
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
I had the same on mine. The bumper had been off for paint when I bought it. The sensor loom dropped down and was melted by the exhaust...... on the test drive!
Rob 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #608552 7th Oct 2021 11:03am
Growl
If it's any help I've had a listen with a stethoscope and none of the sensors are clicking
Post #608646 8th Oct 2021 3:34pm
Chris1573
Sounds like a loom fault. L322 2007 TDV8 3.6
Post #608782 10th Oct 2021 9:28am
bishbosh10
Pretty sure on your car the sensors don't click. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #608789 10th Oct 2021 11:38am
Merchy
A plus on above post, read somewhere that only the earlier sensors make a discernible noise.
To start with, I am assuming that you have a switch for these on the centre panel, does the light illuminate when you press this, if so then could be a wiring problem. If none of them work, meaning front and back then I would check the switch, could be sticking in the 'off' position inside?
Post #608794 10th Oct 2021 1:19pm
Growl
Hi, cheers, I have tried it with both the switch and by putting it in reverse, long beep, light flashes on switch a couple of times but no joy from the sensors
Post #608796 10th Oct 2021 1:56pm
https://www.fullfatrr.com/forum/topic61071.html ... - .- -.
Post #608797 10th Oct 2021 2:38pm
Growl
Cheers, but I've tried 2 new modules in it but no improvement
Post #608800 10th Oct 2021 3:24pm
