Home > Technical (L405) > ATCM-Terrain Response Fault code
davidmg
2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Looked at a couple of 2013 model year 4.4 SDV8's and they both have had this fault code picked up with the IID Tool which would not clear. I am familiar with L322's but not L405's, so wondered what it related to?
U3003-62 (2F) Battery voltage - Algorithm based failure - signal compare failure 2004 4.2 SC Japan Spec
2004 4.2 SC
2004 4.4 AJV8
Post #568085 26th Sep 2020 8:00pm
Sounds related to battery state.
Could be to do with the car sitting for a while.
If the terrain response seems to work and the dash isn’t showing a fault then a new battery or a good charge may sort it. There is nothing that can't be fixed with a hammer😜😜
Post #568115 27th Sep 2020 9:43am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
Re: ATCM-Terrain Response Fault code
Unnecessary quote removed
i have this code with my new to me 2013. i am also having codes related to the gateway module. when the car is fully charged on the battery charger, all the codes except the atcm code clear. they come back after a few hours off the charger. i am installing a new battery on friday when it comes in. i figure a new battery will provide a good baseline to work from.
Post #586153 4th Mar 2021 5:09am
number76
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
Hi Bora20. Did the new battery sort your problems out?. 2014 L405 3.0 V6 Autobiography Santorini Black 49k
Post #607348 26th Sep 2021 8:18am
Bora20
A new battery did not. The code hasn’t made any difference though.
Post #607426 26th Sep 2021 3:35pm
