Home > Maintenance & Mods (L322) > Front Air Strut Replacement |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
As posted elsewhere, my front right airbag blew and I have sourced a replacement. Before getting to the fitting stage i need to confirm a couple of points. I have searched the workshop manual and on line but not getting what I need.
8th Sep 2021 11:27am |
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 |
Surely those wires screwed into the struts are just earth connections |
8th Sep 2021 11:59am |
I believe so but didn't have them on the Td6 (as I recall) so a bit unsure.
8th Sep 2021 12:03pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
As above the brown cables are earths, nothing more. |
8th Sep 2021 12:36pm |
Thanks for that.👍 For some reason I got a bit nervous about it. Onwards and upwards, John
8th Sep 2021 12:43pm |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 |
"Black top thingy" is a vibration damper fitted to vehicles with Brembo front brakes. Page 134 of the WSM. They can be removed from the old strut and fitted to the new one. Be VERY careful removing it though, about £100 to replace!!!! |
8th Sep 2021 2:38pm |
Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 172 |
Thanks got it, but still have no idea how to open this, dont have an Allen key so big and it feels damn tight. Any easy way to open it without damaging. |
8th Sep 2021 2:58pm |
I used a high impact 14mm Hex socket and an electric impact gun. It was not possible to just use a 14mm hex and a ratchet/strong arm as the strut turns as you apply pressure. I did drive my SC for a short while without the braking dampers whilst I figured out the best way to remove them. |
8th Sep 2021 3:19pm |
Thanks for the info re the damper. Presumably the easiest way to remove it when the old strut is removed? John
8th Sep 2021 3:48pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Sorry to hijack I’m going to be doing this soon how did you depressurise the system? I assume access mode then some function in iid tool? Current stable:
8th Sep 2021 11:16pm |
No problem Dan,
9th Sep 2021 7:47am |
Weegie. I did it when the struts were removed from the vehicle, so not sure if it can be done when they are in position. But I think it is likely to be possible. |
9th Sep 2021 11:15am |
Thanks Classic, Yes I think it would be a lot easier - and safer. I am having a problem regarding sourcing the damper and, in any case, would prefer to use the existing one. You seem to be implying that it was a delicateitem or is it just that it is difficult to remove?
9th Sep 2021 12:21pm |
They are made of a dense metal and weigh 0.8kg each, so not a delicate item just expensive to replace if they happen to get damaged on removal.
9th Sep 2021 4:04pm |
