Home > Technical (L322) > recommendations for rebuild of tdv8 4.4 engine
wayne5
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Nara Bronze
hi all
can anybody recommend a good place to get 4.4 tdv8 engine rebuilt...thanks in advance..
Post #602022 27th Jul 2021 7:38pm
Not possible sir... As the parts were never released to rebuild one!
Buy a good guaranteed second-hand one is your only viable option sir... Thumbs Up
Post #602044 28th Jul 2021 12:36am
knwatkins
QP Online...
https://www.facebook.com/qponlineltd/ Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #602048 28th Jul 2021 3:45am
wayne5
aahhh really....are the adverts for recon engines with new parts ect ive found not correct then..???
hence why looking for recommendations...thanks
Post #602051 28th Jul 2021 6:47am
knwatkins
There are plenty of parts to rebuild. It just depends on the extent of what is required. I believe only the engine block and crankshaft are not available as a seperate, brand new part. So, if the engine has thrown a rod and punched a hole in the side of the block, then yes Craig is right a second hand engine is probably the best route. For everything else, a rebuild is perfectly possible.
You can buy parts and they are readily available, for example, pistons, rings, rods, valves lifters, bearings, gaskets etc. You can even buy brand new cylinder heads if needed!
Like I say, it just depends on what you need.
Here are some part numbers to reference for more information:
 Kev
Post #602052 28th Jul 2021 7:31am
Ahh, my apologies sir… These parts must have recently been released… When I last checked, just like the 3.0SDV6 nothing was available from JLR…
Beware of aftermarket companies claiming they can rebuild these engines! Many use Eastern European parts and have no longevity!
Post #602062 28th Jul 2021 9:42am
