Home > Technical (L322) > recommendations for rebuild of tdv8 4.4 engine |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16286 |
Not possible sir... As the parts were never released to rebuild one!
28th Jul 2021 12:36am |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
QP Online...
28th Jul 2021 3:45am |
wayne5 Member Since: 25 Jul 2021 Location: essex Posts: 3 |
aahhh really....are the adverts for recon engines with new parts ect ive found not correct then..??? hence why looking for recommendations...thanks |
28th Jul 2021 6:47am |
There are plenty of parts to rebuild. It just depends on the extent of what is required. I believe only the engine block and crankshaft are not available as a seperate, brand new part. So, if the engine has thrown a rod and punched a hole in the side of the block, then yes Craig is right a second hand engine is probably the best route. For everything else, a rebuild is perfectly possible.
28th Jul 2021 7:31am |
Ahh, my apologies sir… These parts must have recently been released… When I last checked, just like the 3.0SDV6 nothing was available from JLR…
28th Jul 2021 9:42am |
