Home > Technical (L322) > Rear diff heavily corroded |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Take it to a garage to do, a bit of heat and it will come off fine...
15th Jul 2021 7:55pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Mine was so corroded, There was absolutely no way was it ever coming out & believe me I tried everything (Small 12 mm fill plug type).
15th Jul 2021 9:15pm |
Huntneils Member Since: 24 Feb 2021 Location: Oxfordshire Posts: 35 |
Thanks for the advice - I didn’t see the breather, I take it it’s on the top somewhere
16th Jul 2021 6:43am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
Give the area around the fill plug a good scrub with a wire brush, then over the course of a couple of days spray some penetrating oil on it and just before you go to remove it, apply some heat to it and it should come out pretty easily.
16th Jul 2021 11:18am |
