![]() | Home > Technical (L322) > Rear diff heavily corroded |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8394 ![]() ![]() ![]() |
Take it to a garage to do, a bit of heat and it will come off fine...
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
Mine was so corroded, There was absolutely no way was it ever coming out & believe me I tried everything (Small 12 mm fill plug type).
Huntneils Member Since: 24 Feb 2021 Location: Oxfordshire Posts: 35 ![]() ![]() ![]() |
Thanks for the advice - I didn’t see the breather, I take it it’s on the top somewhere
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3155 ![]() ![]() ![]() |
Give the area around the fill plug a good scrub with a wire brush, then over the course of a couple of days spray some penetrating oil on it and just before you go to remove it, apply some heat to it and it should come out pretty easily.
