Home > Technical (L322) > How-to: Start Stop Button Replacement
Page 3 of 3 <123
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
TTB wrote:
Hi Scotcruz,
The part number is LR011898. It cost less than 20 quid from LRI Solutions as "old stock" but they don't have any left. But if you Google for the part number you should find somewhere. LR Direct has them for under 40 quid:
https://www.lrdirect.com/LR011898-supplied...ROVER.html
You can also use part number LR050802, quite a few on eBay for around the £20 to £25 mark.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #598921 27th Jun 2021 2:06pm
VogSe
United Kingdom 2011 Range Rover Vogue SE TDV8 Barolo Black
Just changed my switch, it worked but computer took a dislike to it fault on circuits a and b. Popped switch and changed over the little pcb simple job, old pcb new button all is well in the world took less than ten minutes in total. 61 2012 4.4 TDV8 Vogue SE
Def and discos of old
Post #599933 7th Jul 2021 12:27pm
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
It takes more time to log in, search for this post and reply "It's a s easy as the images show" than actually replacing the cap.
Wink 2012 4.4TDV8
2000 Honda S2000
Post #650281 9th Dec 2022 12:55pm
Cinderrella
Hi all,
Have come from the wiki page, will a £15 unit from fleebay do the job?
Post #685177 9th Feb 2024 11:29am
pcourtney
Yes my ebay one under £20 quid was fine, I just changed mine over, as it was annoying me how the plastic button had caved in so badly on a button used several times a day Sad
If you need some guitar plectrum's to get the Censored out just PM me
Post #686332 24th Feb 2024 9:41am
Page 3 of 3 <123
