Home > Technical (L322) > Tdv8 3.6 oil leek
Landmark
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Tdv8 3.6 oil leek
Hi all, need some advice regarding 2009 tdv8 3.6 l322.
It started with a small oil leak on the driver side down by turbo. I chased it up and found cam cover/inet manifold to be wet around injectors. So after loads of work checked for cracks removed cleaned and reached with new gaskets and that seems to have done the trick....... However there is still a drip cleaned it all up and looks like its coming from just above the turbo to exhaust manifold. In fact it looks like the exhaust manifold. But this makes no sense to me. Car runs great and no faults just need to fix leek. Any ideas.?
Post #596132 1st Jun 2021 7:51pm
Landmark
Tdv8 oil leek
Also friend has suggested could be oil seperator crankcase breather gone bad as this links into rh turbo apparently????
Post #596139 1st Jun 2021 8:55pm
