Home > Maintenance & Mods (L322) > Removable tow hitch square bung cover.....
mjdronfield
I have a factory fit removable tow bar and am intending to spray the receiver so it looks a bit tidier....
Then I remembered/saw that you can remove the receiver, which might be a better option or just an option to paint it easier....
To have the option to leave it off, I need a bung thing to put in the square hole. A quick Google search came up with KYB000011, but it seems it’s obsolete...
Anyone any ideas?
Thanks
Mark
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #593797 10th May 2021 5:19pm
Any US 2" receiver cover should do the trick.
Maybe something like this one ?
Post #593803 10th May 2021 6:10pm
mjdronfield
Cool, thanks. I wasn’t sure if it was a universal thing or not. That’s not a pic of my actual one, if it was that clean, I’d be leaving it 🤣
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #593806 10th May 2021 6:15pm
I never really 'got' that 2 part unit - it seemed to leave so much in place, you might as well leave the whole lot. The only real advantage is that it would store in the boot.
I went from one of those on one car to a farmers hitch on the next - much neater when removed, just a pain to store.
L405 deployable now - the perfect solution Cool
Post #593807 10th May 2021 6:21pm
mjdronfield
I’ve never towed anything, it’s just looking more brown now. Just been and had a look, and I can see nut is 24mm and the whole lot is spinning round. Might cause more trouble than it’s worth......
Will have a better look and perhaps best to tape stuff off and spray in situ.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #593811 10th May 2021 6:39pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
The big advantage of the receiver hitch, along with it heing more robust than the deployable towbar, is the number of different accessories that can be fitted to it Thumbs Up
Google “receiver hitch accessories”.
Post #593816 10th May 2021 7:46pm
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
You will need a spanner on the other side as it is a removable bolt.
Now have a deployable on my Sport so £10 + postage and it’s yours.
Ian
Post #593877 11th May 2021 2:21pm
p38arover
Australia
Why bother? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #593933 11th May 2021 10:14pm
mjdronfield
Thanks for the offer Ian, I’ve painted it now, so will see how it lasts thanks.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #593951 12th May 2021 7:58am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
You can find various rubber plugs for the receiver part on-line - often very cheap.
The one I bought off ebay turned out to be for a metric 50mm square receiver, not the US style 2 inch / 52mm that we mostly seem get in the UK.
At 50mm it was loose in the metalwork, so no use.
I discovered it was quite easy to create some extra raised "ribs" using a hot soldering iron. It now fits fine & definitely won't get easily dislodged (my first plug disappeared while driving !) Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #593969 12th May 2021 9:44am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
How about this one? 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #594094 13th May 2021 8:27am
or this one,
https://www.ebay.co.uk/itm/114798445790?ha...SwRN5gb~R9
or an additional brake light?
https://www.ebay.co.uk/itm/133735946748?ha...Sw5jVgf-AA
or if you can find a clear lens it could be an extra reverse light? ... - .- -.
Post #594097 13th May 2021 8:40am
p38arover
Australia
"if you can find a clear lens it could be an extra reverse light?"
It would have to be better than the ones fitted to the L322! Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #594111 13th May 2021 10:12am
mjdronfield
That’s what I was thinking.... flood light for the rear....
Thanks for your replies. I’ve painted it all now, so I shall leave the receiver connected and see how long my painting lasts.
If it goes scabby again, I will probably remove it.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #594129 13th May 2021 11:41am
mjdronfield
There is a bracket available for lights to be attached on this one....
https://www.ebay.co.uk/itm/265132079573?ha...SwaPhemim-
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #594130 13th May 2021 11:45am
