Home > Technical (L322) > Oh no! Dynamic suspension default |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 84 |
Hi! Not sure what year your car is, but the usual suspect to start with is the wires to the top of the front suspension struts which break over time.
5th May 2021 6:54pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 329 |
Exactly RichT. Sounds like "Adaptive Dynamics Fault" . Check out this post below and do a bit of Googling Cedric.
5th May 2021 6:57pm |
Cedwat Member Since: 15 Dec 2020 Location: NPC Posts: 29 |
Wow ! Great ressource !
6th May 2021 6:29am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
The wiring on top of a rear damper has also been known to fail, but not nearly as likely as on the front dampers because they swivel. |
6th May 2021 9:11am |
9th May 2021 2:40pm |
9th May 2021 2:41pm |
The replacement wiring kit would certain offer a more long term solution but it does look like you have enough wire to attempt soldering in a short piece of replacement wire as a fix for now. 2012 Westminster TDV8 4.4 Indus Silver
9th May 2021 2:53pm |
Cedwat - I recommend installing the proper replacement kit.
9th May 2021 10:53pm |
