It depends upon your car maintenance skills. If you are reasonably competent, there are coolant pressure test / vacuum test / filling kits around, some are not too expensive. But you may also need a compressed air supply for the vacuum use. Have only seen kits with hand pump for pressure testing, not for the vacuum, that is usually with an air supply.If you or a mate have the air supply, bingo.
There are several 'how to use it' videos on you tube etc. Relatively easy to use, especially as you already have the procedure.
Edit - If the extra tool costs are unwanted, at least you have some Independent LR specialists to call upon in Perth. Just as well you don't live in Dampier / Karatha etc
