![]() | Home > Maintenance & Mods (L322) > Air con pulley or tensioner |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
Had my air con re-gassed today and was told that the pulley belt isn't turning the air con pump but the belt is still in place?
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2050 ![]() ![]() |
When I got my TD6 the pulley had siezed. I could not get it out so it went to my mechanic and in the end he took the compressor off |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Easy job. DIY! They use a sprung loaded shock the thing to keep constant pressure and tension in the belt. |
Check the tensioner (number 2 below) is working properly as they are a common fault
Thats the 1 that had siezed on mine |
if the tensioner is seized then the belt wont be turning right?
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
You can access from underneath by removing the front guard first. |
What Richcl said. I took the fan and cowel off as well just to have extra room and to allow the belt to go on easy without feeding it over the fan. |
Is this the thing that is supposed to go click when you turn on the A/C?
You must have a leak in the system Joe90, most probable culprit is the condenser |
Not been using the FFRR due to good weather, but took the opportunity today to dive underneath and see what was going on.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
dont know about 1 and 2 joe,
@ Joe90:
Slow worker but finally got air con looked at (after the hot weather in April things cooled off so not needed ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
