![]() | Home > Maintenance & Mods (L405) > Oil Dilution percentage |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
this thread is all voodoo science to me but it might answer your question,
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Sorry I can’t answer your question because I always rest service indicator as part of my oil and filter service, but I have started logging the rate at which dilution raises from Zero.
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 130 ![]() ![]() ![]() |
Thanks for both answers, to explain the reason for my question is that about 2 months ago I got the service due message because its been 365 days since the car was serviced even though its only done about 6000 miles since the last service and all quite long journeys over 100 miles (I had not had any messages to say oil service due previously ), I had already seen a video that showed how to reset the service message so thought I would try it and it worked so message went away, recently i have read a few bits on hear about oil dilution and having treated myself to a Gap at Christmas thought today I would get the reading which has come up as oil quality fuel dilution factor 0.488 and distance since diesel partial filter regeneration 527km so was wondering if it was a true dilution reading or I have reset it in which case I will do an oil change to be safe. |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
TBH I had the same quandary as you with low mileage this year, I decided to change the oil anyway as 12 Months or the stated mileage has always worked for me, a bit different now with DPF’s but the 12 Month marker should be adhered to IMO. |
IIRC yes it will reset it to zero when you click service reset. I had a high reading of 12 oil/fuel dliution when I bought the. car and did an instant oil change and reset using my IID tool.
My service required l warning flashed up yesterday.
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
Probably an incredibly stupid question but ...
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
It resets back to 0% |
dunno about that but if it was serviced at a dealer with access to the JLR online service history then you can see on that site,
GAC23,
Thank you @Stan and @Baltic Blue.
