Home > Technical (L322) > 2003 4.4 v8 error
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
2003 4.4 v8 error
Hi all
So as some of you may have read I've been pretty busy with the car doing service, rocker cover gaskets and the alternator. The spark plug wells had a bit of oil in each spark plug hence why ive done the rocker cover. Car was all put back together however it struggled to start so called the aa to jump start it only to find its misfiring. Aa come back and said its come up with codes
P0204 & P0304 being injector faults
He suggested to double check the injector wire to make sure it's definitely connected first as that could be the issue and said if not then it's either going to need a new injector or new wiring loom
Anyone had this issue in the past and able too advise on any other ideas
Cheers all
Post #579014 8th Jan 2021 9:19pm
That's a misfire and a wiring fault on cylinder 4... you probably dislodged the connector or damaged the loom during dismantling and assembly... Thumbs Up Pete
Post #579022 8th Jan 2021 10:36pm
Bean19844
Cheers haylands. Guessing it's a job of inspecting the wiring, connection and fixing as required. Hoping it's something simple like I forgot to plug the connector back in
Post #579025 8th Jan 2021 10:51pm
Thumbs Up Pete
Post #579026 8th Jan 2021 10:56pm
Bean19844
Well Al is going to award himself prat of 2021 trophy too himself. Had a quick look at the wiring, coils etc. Start looking at number 4 Injector and guess what injector is currently facing the wrong way to the engine fire wall :whistle Whistle .... Yep that would explain the rough idle, wiring faults and the struggle too start.... Taken it for a bit of a drive and it feels lovely and smooth so order restored.... Now time too sort the bike
Post #579082 9th Jan 2021 1:59pm
