Home > Maintenance & Mods (L322) > Side Step/Running Boards?
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Mine was mostly because of how rusted they was so to fit fresh bolts would mean removing the air tank but if yours already has the holes without any bolts in situ then you should be laughing. Only thing I'd suggest is get a ratchet strap to pull both main bars into alignment for bolting to the chassis
Post #577366 27th Dec 2020 2:34pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
Cheers, I have some ratchet straps, will make sure I have them handy when I start! 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #577385 27th Dec 2020 4:03pm
Bean19844
No dramas mate. Like I say they fit pretty well n I'm happy with them. While they are off might be worth while adding some rust proofing to the bars just to help strengthen them
Post #577386 27th Dec 2020 4:17pm
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Ricardo Villa wrote:
This is the Ebay code, supplied by 4x4Direct. eBay Item No. 392361938579
Hope you find easily.
Managed to get a 20% Voucher so £119 delivered
Post #579259 10th Jan 2021 11:28pm
Bluespanner
United Kingdom 2012 Range Rover Vogue SE TDV8 Baltic Blue
I’m not keen on my deployables, half the time they seem to get stuck, even with regular cleaning and wd40. I’ll probably have to strip them completely and rebuild with fresh lube but it’s a faff that I can’t be bothered with at the moment.
Post #579269 11th Jan 2021 8:39am
TeeMyob
Side steps awaiting fitting. Mine did have steps on at some point so hoping holes etc will be all ready!
Mine arrived with no instructions
Post #579455 12th Jan 2021 4:16pm
Ricardo Villa
So did mine, had a parts list but no fitting instructions. If you ring them they will email you some but there are videos on YouTube that cover it pretty well. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
Post #579456 12th Jan 2021 4:18pm
Bean19844
Easy enough. Place bolts into the sills and hook side steps onto them
Chassis rail bolt, line up and tighten up
Ratchet strap may be needed for the next part but repeat process for next chassis rail then tighten all up
Pop wing cover off, install plate, then attach mudflap
Post #579470 12th Jan 2021 5:34pm
