![]() | Home > Maintenance & Mods (L322) > td6 oil in expansion tank |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
I’m not an expert, so might not be related in any way..... have you changed the crankcase breather or replaced it with a vortex one from a later BMW?
wicklowRRirl Member Since: 01 Nov 2020 Location: wicklow Posts: 4 ![]() ![]() ![]() |
I haven't replaced that but will throw it on there growing list |
The filter one can get blocked, not sure if that would then send oil where it’s not supposed to be. Fit a vortex one and you will never have to change it again.
There's an engine oil cooler bolted to the rear of the oil filter assembly. It's a plate heat exchanger, engine oil on one side of the plates, engine coolant on the other side of the plates. It's not inconceivable one or more of the plates has corroded through allowing oil to mix with the engine coolant. |
thanks for the reply ,
thanks for the replies , after popping off the oil cooler and a few choice words the problem looks like the oil cooler gave in.
Got there in the end. Least it’s easy to get to.
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
I have found the best thing to clean oil out the rad is a tin of petrol injection cleaner, start by flushing the rad out as best you can then fill up and add the injection cleaner run the engine till it is properly warmed up, flush rad again several times with clean water follow up with some proper rad flush (yes its a lot of flushing) and the cooling system will be cleaner than a clean thing on cleaning day, over the years I have had this job on several different cars and it works a charm. |
