Home > Technical (L322) > Battery failure on its way? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
the older FF's are indeed heavy on the batterys and 4 years worth aint to bad.. ... - .- -.
6th Oct 2020 3:35pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Before you go out and buy a battery it would be useful to check the alternator voltage if you can. Should be at least 14.1V when on a run. |
6th Oct 2020 3:55pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
You really don’t want it to be the alternator Got - 2017 SDV8 Autobiography in Loire Blue
6th Oct 2020 9:00pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Yes I do not want a new alternator, water cooled, a pain in the a*** to change never mind the cost.
7th Oct 2020 7:40am |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Sure I read somewhere in the past that's it's recommended to fit a new battery every 3 years. |
7th Oct 2020 5:57pm |
I’ve had 3 during my tenure of 8 years. Got - 2017 SDV8 Autobiography in Loire Blue
7th Oct 2020 6:46pm |
so getting 4 years out of this battery is quite good!!
8th Oct 2020 7:11am |
the brake switch behind the pedal gets stuck so remove and a clean might help... ... - .- -.
8th Oct 2020 8:10am |
I'll check that, im also checking if water ingress on the drivers side over the LCM.
8th Oct 2020 9:16am |
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 234 |
When ever anybody mentions a fault to me with any LR I always suggest checking the battery before anything else. All of them draw so much on initial start up and as you are experiencing unless they get a good run the alternator just doesn't get enough time to chuck all those wiggly's back into the battery.
8th Oct 2020 3:35pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Getting to that time of year when the C tek (other makes are available) comes into its own! Previous cars:
8th Oct 2020 4:12pm |
An update to close the thread down.
13th Oct 2020 8:26am |
