![]() | Home > Maintenance & Mods (L322) > Load Cover Parts |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1544 ![]() ![]() |
Photograph?
tpeat12 Member Since: 18 May 2020 Location: Glasgow Posts: 69 ![]() ![]() ![]() |
Cheers for the quick response. My photograph uploaded to the Gallery but I only just worked out how to imbed it in the message |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
As a temporary fix, could you fit some heat shrink tube over the bolts? Cheers
breakers is probably your best source, load cover along with the side panels .
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
I did something very similar although I used solid brass rod with heatshrink, because where the guides fitted the cover had been broken. Only notices when the cover is up. 2003 Range Rover Vogue TD6 |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
I have 2 x HM1 and 2 x HM2 if you are interested. All are brand new still in packaging.
Thank you all so much for your responses. I'll see if any local breakers have any load covers in good condition but if that falls through i'll let you know.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
A member (warninglight) is planning on 3d printing these in the near future, I sent him my broken one a few days ago to copy.
Good effort if they succeed!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I bought some new ones from the local LR dealer. Not daft money. Can you not buy them separately anymore? 2011 Range Rover Vogue SE 4.4 TDV8
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 ![]() ![]() ![]() |
They are easily available from any dealer or LR parts place, e.g. Island 4x4: https://www.island-4x4.co.uk/pin-epn000010puy-p-37279.html .
Thanks Paul,
HM1, at the tailgate end of the shelf, are actually EPN000020PUY, and seem to be the ones most commonly breaking and needing replacement for the moving flap. That's certainly what I ordered and fitted from Duckworths for one of my shelf pins closest to the rear of the vehicle, and was perfect.
Sorry about that:
