Home > Technical (L322) > Colour black
paul70
Colour black
Quick question 2011 vogue is it santorini or java black.
Thanks, Paul
Not been on the forum for quite a while as not been well but want to get back on the horse as it were!
Post #555281 25th May 2020 6:30pm
PeteT80
It’s written on the near side suspension turret under the bonnet.
Post #555289 25th May 2020 6:50pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
They did three blacks in 2010/11, Santorini, Barollo (reserved for Autobiography Black) and Sumatra Black. You will find it could be either, check the panel as will tell you, Santorini was stopped for a while due to the Tsunami in 2010 as some of the paint flakes became unavailable. I had one of each in 2010 i personally preferred Santorini as has a more noticeable fleck Thumbs Up
Post #555307 25th May 2020 8:31pm
paul70
Thanks for the info. Found the plate on the suspension turret. It was covered in filth so not all that obvious. Now know it’s Santorini so can get on and order some paint to hopefully sort a small scuff.
Post #555419 26th May 2020 7:45pm
