Home > Maintenance & Mods (L322) > Possible Alternator failure |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 337 |
Yep, sounds familiar. When the alternator seizes, it will stall the engine. Had this on my 4.4. It may have flat spotted the belt so I’d replace both if it is the alternator. |
28th Apr 2020 6:45pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
Thanks for the reply. Did you replace it yourself? And did you replace tensioners too?
28th Apr 2020 7:19pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8192 |
Download the workshop manual from WIKI, it's in there, not too bad a job, change the idlers if they feel rough or are noisy at all when you spin them, check the water pump, mine had play after the alternator seized so I changed it anyway... Have fun.. Pete
28th Apr 2020 10:50pm |
29th Apr 2020 9:55am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Sounds definitely like the alternator.
29th Apr 2020 1:46pm |
Got the old alternator out, very hard to spin so seems to be a duff bearing.
5th May 2020 7:26pm |
No, it should push all on it's own and put resistance on the belt... Pete
5th May 2020 7:35pm |
Ah, so is it more like a dampener? Both the top bracket and bottom assembly either side of the hydraulic cylinder pivot freely. When on the engine the top pulley wheel is at a fixed point but the assembly with the second wheel can rotate on that axis point.
5th May 2020 8:11pm |
TBH it was a few years ago I changed one... both the wheels were rough on mine, the damper does something to tension but exactly what I can't remember...!! Sorry.. Pete
5th May 2020 9:02pm |
Thanks Pete. The bearings on the pulleys seem fine. As long as it’s all meant to move freely when off the car and then physics makes it tension when the belts on that’s good enough for me. |
5th May 2020 9:13pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
When I did mine I changed the lot as they had been there for 10yrs also changed the water pump same as Pete all preventative maintenance |
6th May 2020 8:28am |
