Home > Technical (L322) > Odd gearbox behaviour |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Might be worth replacing the solenoids and valve body seals if a full rebuild or replacement is out of budget. |
29th Apr 2020 10:58am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
I'd double check that the level is correct as a first option |
29th Apr 2020 11:01am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
Yes, check the level first. I think it needs to be warm but double check.
29th Apr 2020 11:23am |
Just look at the post and the Wiki workshop manual for level check and filling.
29th Apr 2020 12:45pm |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
Great, thanks for the advice. I'll check the fluid level first and see how that is. |
29th Apr 2020 1:04pm |
If the fluid is correct the seal that joins the mechatronics block to the main gearbox case can go hard and leak internally loosing pressure and introducing air in the system that takes a while to purge. |
29th Apr 2020 4:45pm |
This one. |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 |
That's a coincidence, I was going to post the same question as the OP. I have recently found that mine does the same thing if I don't use it for a week or so, same delay in drive or reverse if I wait with the engine at tickover, maybe 5 seconds. Any increase in revs and the drive is there immediately. Gearbox oil was changed by indy 3 years ago just after I got it at 116K miles (20k miles since) but no megaflush as far as I know and they had to put some shudder fix in afterwards as it was 'cattle-gridding' on hills.
29th Apr 2020 9:11pm |
