Home > Technical (L322) > Air suspension...Again |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8191 |
My guess would be a minor leak started it off, the car drops and a new part of the wheel height sensors comes into play, this is probably dirty so there is little electrical imput to the suspension ECU, the fatty thinks it is constantly too low so pumps up, sorry to say but it is usually the bags that burst, around the fold of the air bag...
17th Apr 2020 5:30pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
Agree, most likely an air spring (typically one of the front ones) has sprung a leak/hole around the fold. Several of us have had that lately around the 8-10 year old mark...
17th Apr 2020 7:59pm |
Lee67 Member Since: 06 Mar 2019 Location: Surrey Posts: 7 |
Thanks for following up on my question gentlemen. I appreciate the input.
18th Apr 2020 6:56am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
also check the orientation of the height sensors, if it has over extended itself its possible one has become inverted the wrong way round and is giving a spurious reading.
18th Apr 2020 5:21pm |
Hi,
18th Apr 2020 5:43pm |
dont have a pic of normal sorry but they should be pointing the same way if that makes sense. A diagnostic tool should be able to tell if there is a discrepancy in the readings and one of the sensors is duff tho.
18th Apr 2020 5:58pm |
Thank you.
18th Apr 2020 6:02pm |
All air suspension cars and Fatties have height sensors, it has nothing to do with VDS, that controls damping not ride height...! Pete
18th Apr 2020 6:22pm |
18th Apr 2020 6:37pm |
Sorry, not up on the controls of the later cars... maybe ask the dealer, they can tell from your VIN... Pete
18th Apr 2020 6:39pm |
OK. Thanks.
18th Apr 2020 6:42pm |
If you have wires going into the top of the strut then you have Adaptive Dynamics (VDS) There is nothing that can't be fixed with a hammer😜😜
18th Apr 2020 7:08pm |
Thank you very much for all your help. Much appreciated.
18th Apr 2020 7:11pm |
