![]() | Home > Maintenance & Mods (L322) > Tow Bar Query |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Have you got a blow torch? also spray loads of wd40 on it for the next couple of days so it can work into the gaps and hopefully loosen it up. |
I have a similar challenge, brought the RR last week and this is the towbar I was handed.
neil3728 Member Since: 24 Feb 2020 Location: Howden Posts: 51 ![]() ![]() ![]() |
Looks as good as mine, |
I have no keys for r so have managed to get new neck bit off flebay with keys and hopefully can drill out the old lock and separate these so i can use the attachment then I need to find the correct bolt to hold the thing into the square fitting. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Plusgas would be better. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
There is a good video on U tube about how to take one apart without the keys. no drilling needed just a hammer and a punch, to get the lock mechanism out. 2011 Vogue 4.4 TDV8
thanks will do a you tube search. |
Big hammer won the day. Amazing how easy it came out with the correct tool.
