Home > Technical (L322) > What does this part do? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Fuel cooler PN LR031827. John
1st Mar 2020 6:26pm |
Double post John
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3141 |
thx John. is a leak likely to lead to RP? Even when not in RP it seems underpowered. Could it be a simple leak or is it more sinister?
1st Mar 2020 6:48pm |
If there is a leak then I would think that the fuel delivery would be affected which in turn could lead to RP and loss of performance. John
1st Mar 2020 7:01pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
They are your fuel pipes James, coming from the diesel fuel cooler unit and should be under VERY high pressure sir... |
1st Mar 2020 10:25pm |
Thanks Craig. Have checked alignment and fitting - if they are high pressure lines do they have an o ring which could split/leak? |
2nd Mar 2020 9:06am |
