Home > Technical (L322) > TDV8 turbo noise |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
Presume no error messages or limp mode?
10th Feb 2020 10:42pm |
Chlorothalonil Member Since: 08 Sep 2018 Location: East Yorkshire Posts: 53 |
No, nothing at all. Will see what happens when I fit the hoses, and will check for other possible leaks. |
11th Feb 2020 10:04pm |
New upper intercooler pipes fitted but no change. Will check exhaust manifold. |
16th Feb 2020 5:30pm |
Not easy to even see the exhaust manifold. Check for missing studs/ nuts. |
16th Feb 2020 8:53pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Mine makes a noise (when warm) best described as the VW air cooled engine. I suspect it’s a blowing exhaust but I’m told that the studs are intact. The ones we can see anyway.
22nd Feb 2020 7:59am |
https://rover.ebay.com/rover/0/0/0?mpre=ht...4039208033
22nd Feb 2020 10:21am |
Still making the noise but no codes or smoke. Cannot see any cracks. Will have to check studs. |
25th Jun 2020 9:51pm |
Well, I give up. It is booked into a local garage next week for them to have a look. |
14th Jul 2020 10:36pm |
Garage 1 reckons it could be the nearside turbo but won't do the job.
28th Jul 2020 9:24pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
That’s not ideal then. At least if you have a proper diagnosis, you can decide if you need to worry about it or not.... 2011 Range Rover Vogue SE 4.4 TDV8
28th Jul 2020 10:24pm |
Second garage said they don't know what it is and didn't seem to want to help.
31st Jul 2020 8:39pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Time for a smoke test? |
31st Jul 2020 9:31pm |
Think so. Just need to find a garage with the kit. |
31st Jul 2020 10:20pm |
Not managed to get a smoke test yet. Just wondered if anyone had any other ideas as to what it might be? Hard to get it to a garage with current restrictions. |
10th Jan 2021 8:35pm |
