Home > Technical (L322) > 4.4 tdV8 iid Live values.
Baltic Blue
I thought I would record some Live values whilst car is running well.
I have permanently got the 2 Fault codes showing that won’t reset, but they have been showing for at least 12 months and not giving any noticeable issues.
All readings were taken after a 5-6 mile run to bring up to working temperature.
Engine running on Tickover .
Post #484440 27th Jul 2018 10:26am
GGDR
Hi Mike, could you pls capture that last set after you've don a run / once the engine's proper hot?
Cheers,
Greg Cheers, Greg
Post #484444 27th Jul 2018 11:10am
Baltic Blue
I was going to do that Greg, because I can’t believe they are all faulty, if 100 is the default reading?
I am also thinking that it may be overcharging slightly.
I fitted a new battery 3 weeks ago, but didn’t do a reset because both Nino and Dolph34 were saying they were getting low charging following a reset.
I believe the capacity should be approx 82% but mine is showing 94% . It certainly turns over quicker than it used to with the old battery.
Post #484445 27th Jul 2018 11:24am
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
I did a 300km trip this weekend and recorded some live values.I would like to hear what other members read.
Ambient was 32°c.
Water temp run at 92°c when cruising @ 125km/h.Climbing a pass it quickly rose to 102°c and stayed there.
Intake air temp about 6°c more than ambient.
Charging stayed at 13.8-14v.....I thought it should vary uphill and downhill.No intelligent charging here.New battery and daytime.Aircon on.
Level cruising use 40-50% power.Car will downgear at 80% power used on incline. 2012 TDV8 Vogue SE 4.4
Post #542860 3rd Feb 2020 10:55am
