Home > Maintenance & Mods (L322) > Sat Nav Software and Map Upgrades
AMD
As I have a 2006 SC with RSE, I assume I have the Denso Sat Nav unit as apposed to the BMW MkIV unit ??
Where is the best place to get any firmware updates and map discs?
Thanks Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #48942 5th Feb 2011 11:41am
you can download freely from here. http://rapidshare.com/files/387720328/Land_Rover_Navi_DVD.txt ... - .- -.
Post #48943 5th Feb 2011 11:56am
AMD
Thanks Scary.
I also want to have the update to use the Nav on the move which means handing money over to the dealer. So I'm considering a Garmin, Navman or similar as a more effective solution than the RR nav. Thoughts? Current MY2020
Post #49052 5th Feb 2011 8:35pm
nav on the move is expensive..i tend to put all my destinations in at the beginning then when on the move i pick recent destinations...the beauty of the built nav which is very good btw, is an aftermarket nav has to be fixed up at the start and taken down when you reach where your going, not to bad at the beginning but this will annoy you after a while.. ... - .- -.
Post #49056 5th Feb 2011 8:45pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Sorry to be dense, but what do you mean by nav on the move? 2012 SDV8 Vogue SE
Post #49064 5th Feb 2011 9:34pm
dan_uk_1984
The later models - 2005+ do not allow you to enter an address whilst on the move - although I thought this was a "market restriction"? Could be wrong though as I dont know much about the newer ones...
Your 2002 Bozman is fine though, mk3 and mk4 did not have this limitation.
Post #49071 5th Feb 2011 10:28pm
sportin
United States 2006 Range Rover HSE 4.4 V8 Java Black
Follow this link...it explains how to make it work on the fly...works like a charm on my06 HSE...if you shut the car off, you would have to do the procedure again to make it work..
http://rangerovers.net/forum/viewtopic.php?f=5&t=7209
Post #54260 12th Mar 2011 3:31pm
whilst on a journey yesterday i used the 753 code and tbh i cant see the excitement about watching tv on the move ..i found the picture and sound fading in and out and the cost of getting this feature working really isnt worth it.. ... - .- -.
Post #54274 12th Mar 2011 4:32pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
if you have access to an IDS system (diagnostic stuff) you can do it by yourself. There is a how to for the dealers on LR's topix system.
Post #54278 12th Mar 2011 4:52pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
753 can allow front passenger to watch a dvd film aswell though , but the only time I have found it useful is when sat in traffic and I am stop starting a lot and don't want to keep putting the car out of gear and the handbrake on just to see the TV for a few seconds (as the other annoying thing is that when you do use the normal method, the screen is always shrunk back on the left hand side of the screen again and you have to tap it to resize it to full screen each time you stop - dumb!). Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #55532 18th Mar 2011 10:54pm
luckily i've not been in a traffic jam since having the range , but i can see the entertainment value in doing the 753 in a jam.... ... - .- -.
Post #55624 19th Mar 2011 4:28pm
