Home > Technical (L322) > Dead parking sensors all round L322 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Have you had codes read with a plug in diagnostic yet? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Jan 2020 7:34am |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
As far as i know even 1 sensor not working will stop all.
17th Jan 2020 8:28am |
kaoleary Member Since: 14 Sep 2013 Location: Hertfordshire Posts: 26 |
Thanks for your replies. I have a generic OBD scanner. Will that find it? |
18th Jan 2020 6:14pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 517 |
No. When I had a similar problem it was the loom which had corroded. You could either get a LR code reader or try removing the bumpers and take a good look around. The damaged areas were pretty obvious. 2016 Skoda Octavia VRS Estate
18th Jan 2020 6:48pm |
Both bumpers need a little paint, so I think I'll take them off and investigate. Thanks for helpful replies |
19th Jan 2020 11:22am |
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 |
Had the same issue, mine needed two new ultrasonic sensors on the rear.
19th Jan 2020 3:45pm |
