Home > Technical (L322) > Pre-wheel alignment, what do I WD40 to avoid probs on ramp
GGDR
Hi team,
I've read a few peeps have had issues getting wheel alignments done due to rusted up bolts/threads.
Could anyone give me a crib list to WD40 before I head to the ramp so I can avoid problems?
Cheers, Cheers, Greg
Post #539465 5th Jan 2020 1:01pm
Baltic Blue
Have you read the 4 wheel alignment PDF in the suspension section of the W M Greg ?
It shows adjustable points, which seems a good starting point.
Post #539470 5th Jan 2020 1:22pm
GGDR
Ah you must mean the instruction manual?
Shocked
Standard bloke kryptonite.
. Cheers, Greg
Post #539471 5th Jan 2020 1:25pm
Baltic Blue
Rolling with laughter Rolling with laughter
We sweat blood downloading it so that we could find the answers to help members with questions like this.....
If all else fails read the WM. Thumbs Up Thumbs Up Thumbs Up
Mike
( Happy New Year Greg) G reg 2.5VM Vogue Portofino red 1991- 1999
Post #539473 5th Jan 2020 1:38pm
Wouldn't bother with wd40, you need a good quality release oil such as Plusgas, and lots of it.
I would dose everything every day for a week but the chances are a gas torch will still be needed.
Post #539514 5th Jan 2020 6:06pm
DrRob
Agreed. I had to have new rear tie rod thingys fitted. Old ones were Censored Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539526 5th Jan 2020 6:44pm
GGDR
Cheers, PlusGas ordered Thumbs Up
For the rear (now I've read the manual Rolling Eyes )
It seems there are two adjusters.
Is the lower one in this pic the one you're talking about Rob?
. Cheers, Greg
Post #539550 5th Jan 2020 8:57pm
DrRob
It was these IIRC
https://www.advancedfactors.co.uk/rgd50018...1716-p.asp
Paul at Advanced Factors sorted it all for me when I left it at Hutfields in Botley for the alignment. One of a few places that has an IID to lock it into Tight Tolerance Mode and understand why etc Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539556 5th Jan 2020 9:17pm
