Home > Technical (L322) > DPF diary B.B.
Baltic Blue
DPF diary B.B.
Just thought it worth sharing my latest DPF figures, just for comparison.
I have just returned from a few days in North Wales, basically 125miles motorway each way with a couple of local stop start mid way.
Home 17.5g
LLanberis 19.0g
So 1.5 g increase in 125 miles.
Local stop/start ( 4miles) 19.4g
Return trip
Peaked at 19.5g
Down to 2.1g soon after joining A55 (70mph dual carriageway)
4.7g back home.
Very happy bunny Thumbs Up Thumbs Up
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #537384 14th Dec 2019 2:55pm
DrRob
Have you ever had a yellow DPF light come up? Just wondered why you’re worried about monitoring the numbers?
Did you go to Petes Eats for a fry up? I grew up very close to Llanberis Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537387 14th Dec 2019 3:37pm
Baltic Blue
Rob,
I have never had a DPF warning light of any colour, but I do a lot of local stop- start trips and like to know when it’s getting over 17g so that I can plan a good burn trip.
No I didn’t go to Pete’s Eats, but my daughter has just moved into a new house a few yards from it , so will be visiting regularly and will no doubt give it a try.
We did a brilliant walk yesterday afternoon ,in glorious sunshine, all the way around Llyn Padarn.
It has got its ups and downs on the far side., but well worth the effort.
Post #537391 14th Dec 2019 3:57pm
DrRob
Gotcha Thumbs Up
I got off the A3 a few days back and it really smelt hot. It’s a very distinctive odour. IID showed soot was very low (1.9g I think) so I reckon it had just done a nice big burn 🔥🔥👍 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537407 14th Dec 2019 4:38pm
Baltic Blue
Thumbs Up The exhaust temp was showing 625-630 deg for over 5 miles, which is pretty hot Thumbs Up
Post #537410 14th Dec 2019 4:47pm
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Mike, what are you using to interrogate the ECU to give that level of data?
Post #537802 18th Dec 2019 4:54pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
He's using a GAP iiDtool 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #537806 18th Dec 2019 5:08pm
Baltic Blue
I have my iPad mini Bluetooth connected to my Gap iid and select the relevant live values, then just take screen dumps to keep a diary.
Post #537817 18th Dec 2019 6:34pm
supershuttle
I do both short trips and long trips (for example today did about 60mls each way)but seldom went over 70mph Whistle which means the revs were only about 1300 will this still do "the burn"? Geoff
Post #537818 18th Dec 2019 6:50pm
Leesbay
England 2011 Range Rover SE TDV8 Zambezi Silver
⬆️Yes as long as its above approx 50mph for 10mins plus👍
Post #537819 18th Dec 2019 6:55pm
DrRob
Yes, but you should also regularly rag it above 2500rpm to get the second turbo working and clear the crap out of the engine. Nothing to do with DPF but such a lazy engine they rarely get the taps opened up fully Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #537820 18th Dec 2019 7:11pm
Baltic Blue
Geoff,
Speed is not important, nor are revs... just keeping a steady throttle setting is though.
If you can set the cruise control to 60mph on a motorway run for 10- 15 minutes ( miles) passive regens will keep your soot levels down, but when they get over 19g then the car will activate an active regen where fuel is injected and burns in the DPF, bringing the temps to 620-30 c and the soot level falls rapidly into single figures down to 2-3G.
It’s a bit addictive watching it happen, but I have got to know exactly how my car is doing, so once it gets down low I ignore it for 2-3 weeks before monitoring it again.
Post #537823 18th Dec 2019 7:21pm
neilly
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Sounds good to me, Very Happy
How do you define as rag it? a nice country lane making use of the paddles and keeping the revs above 2500 ? or finding a nice "private" road that high speed can be maintained? For either how long for?
Cheers
Post #537824 18th Dec 2019 7:22pm
neilly
Baltic Blue wrote:
Geoff,
Mike.
In the New Year, I will have to check mine for a week and see how it goes, as I have a daily 85 Mile commute , 80 Miles of it on Mway.
I like this sort of thing.
Cheers
Post #537825 18th Dec 2019 7:24pm
supershuttle
Yep, I do that using the paddles to knock it down a few gears on the motorway Thumbs Up as this forum has made me paranoid about not having done the Turbo Drain Mod. Geoff
Post #537826 18th Dec 2019 7:28pm
