Navigation/Screen/ Stereo issues | |
So first issue with my new purchase that I'm going to tackle. 2004 vogue with the BMW style infotainment.
On collection yesterday I notice the navigation wasn’t working, the screen was working via the TV modules output and the radio worked for 2 hours no issues. The PO has replaced Yil000023 which I think is the tv tuner (listed as entertainment module?) ? Blue and white plug with two antenna. The original (which came with the car) has some water damage. On getting home I thought I’d see if I could get the navigation to work so I disconnected and reconnected it. The power light came on and it started up using the navigation computer’s display out put and all was fine. With the screen now working, navigation knew where we were and displayed the map and the radio was working. Locked the car and left it overnight.
Today I’ve come to use it and the display is blank, the backlight comes on and the radio worked for a few minutes and stopped. Turning the head unit off and back on (left knob) would return the sound for a few minutes. On first inspection in the boot I noticed that the nav drive did not have the red power light.
Unplugging the nav computer and plugging it back in again causes it to start up properly and the display to work and the radio then works fine for as long as required.
Once the car has been locked and it’s gone to sleep, red light goes off as it should but when starting the car again the navigation computer does not wake up unless I unplug and plug it back in again.
So my question is, is YIL000023 the tv tuner? It’s plugs I believe will fit the navigation computer and we can do away with analogue TV? (Is that correct?) or should I just get another analogue TV tuner and try that? Can I at least temporarily plug the navigation computer into the two connectors for the entertainment module/TV Tuner?
Also what wakes the navigation computer up? Does the entertainment module/TV tuner instruct it to start up? Or despite it working perfectly once manually started is it still at fault for not starting up when the car is unlocked?
I have tried to search for a schematic of the DSP system in a Vogue and as far as I can understand there is the Screen, BM54 as the radio module, MK3 Navigation computers, the DSP amp and the entertainment module/TV tuner. Is that it? Or are there more components in the system? Does anyone have a diagram of what is connected to what? 2005 E60 M5
2006 (MY07) L322 4.2 S/C
2024 i7 xDrive60
2004 L322 4.4 Vogue, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C , 2001 P38 Vogue, 1999 P38 4.6 HSE.
