Home > Technical (L322) > Help please - dropped hose spring retaining clip!!! |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Are they not simply the spring hose clips ?
24th Nov 2019 6:50pm |
TDV8John Member Since: 08 Nov 2015 Location: Kent Posts: 19 |
Hi thanks for the input John but no it wasn't the usual spring hose clip otherwise all would have been well.
24th Nov 2019 6:58pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3766 |
Nino Nino is your man.
24th Nov 2019 7:17pm |
OK, I've done a search as I was sure it was a spring clip.
24th Nov 2019 7:22pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Any clues on this thread
24th Nov 2019 7:25pm |
Thanks again guys for the swift help.
24th Nov 2019 7:38pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Could you use one of those extending magnetic pens to wave it around in the hope of snagging the clip?
25th Nov 2019 9:24am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
TDV8John
25th Nov 2019 9:34am |
Mike/Nino
25th Nov 2019 9:49am |
Any help ??
25th Nov 2019 10:09am |
Perfect, that's the one in purple Mike.
25th Nov 2019 10:15am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
You could try hosing down the side of the engine to see if you can wash the clip out. |
25th Nov 2019 10:49am |
Would taking the air filter box out help you to get easier access?.
25th Nov 2019 11:25am |
Yes tried that but no luck unfortunately. |
25th Nov 2019 11:39am |
