Home > Technical (L322) > Flip key conversion? |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
Yes done working the issue is if you leave the copper coil and 8 legged Ic in you will have issues as with your key transponder inserted you then have 2 and the BCM will not reconise |
6th Mar 2011 7:09pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
so you are saying remove the 8 leg chip but leave the copperwound component attaced and this will charge the exsisting batt, sorry what year is your car
6th Mar 2011 9:22pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Davo,
7th Mar 2011 1:24pm |
within the copper coil is a ferite and fiberglass slither this provides the core to the coil for battery charge a bit like the iron core of a transformer the IC is the transponder |
7th Mar 2011 5:28pm |
now this is getting confusing, the transponder is with in the copper coil, it does not need any type of power to work this part is correct.. the copper coil around the transponder is to charge the key, i think this is correct.
7th Mar 2011 5:29pm |
say your car has a diamond key if you remove the 8 leg IC and put it in another key that key will start your car Proven
7th Mar 2011 5:41pm |
hi, ok if the IC/Chip is the transponder and removing it removes the transponder funtion when you use the board minus the chip in a remote with the correct key cut it will start it.... but would the new car you are using it on be looking for the transponder. V8 facelift Range Rover Autobiography 22" wheels.
7th Mar 2011 5:50pm |
try this
7th Mar 2011 6:00pm |
quick one..did you use the original transponder "small carbon chip a bit like a magenet" from you key in the new key.... V8 facelift Range Rover Autobiography 22" wheels.
7th Mar 2011 6:23pm |
Hi Daveo
7th Mar 2011 6:30pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
i thought the battery charging feature was on the older bmw keys and not on the keys used in the 02-05 range rover
7th Mar 2011 7:16pm |
read the above post to the end |
7th Mar 2011 7:22pm |
HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244 |
I just had the same idea. But my car is a facelift (06)
9th Mar 2011 7:23pm |
The keys used in the 02-05 Range Rover ARE the old keys - Circa 1991. The newer BMW keys charge, but they weren't given to the RR. Lets face it, BMW kept all of the good tech away from the RR. Thats why the 2002 RR had the mk3 nav and the X5 had the mk4 etc. |
9th Mar 2011 7:26pm |
