![]() | Home > Technical (L322) > Park assist not working |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
Has it ever worked in your ownership? 2016 Skoda Octavia VRS Estate
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Any tone from the front or rear? Even briefly? If it’s completely dead then yes your correct sir, check fuses first... Then it’s a plug it in job for diagnostics. If no fault codes check the PDC ECU is in the list of ECU’s found! 👍 |
Rude Member Since: 14 Apr 2019 Location: Knebworth Posts: 27 ![]() ![]() ![]() |
Thanks chaps
Bizarre. Worked fine today then stopped working again... loose wire or something more sinister...??? |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 ![]() ![]() ![]() |
Mine are doing the same idd tool says sensors are working |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
I’ve got the opposite mine works but iid tool can’t find the module |
