Home > Maintenance & Mods (L322) > Short rear number plate
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
When I got my car I stuck my standard size number plate onto the boot of the car. As I only have 5 characters in the plate I’m now considering if I can get a shortened plate made up for the back, with standard size letters to keep it legal.
Problem is, I remember there being a recess behind the rear plate because I had to put the sticky pads around it to make sure it stuck. I don’t want to pull the standard plate off to have a look cause I know it’ll be a pain to clean all of the glue off the boot.
Does anyone know what the shortest size plate is that I can fit on the back but still have enough panel to get it to stick?
Or is there something that can fit in the recess to allow it to sit flush?
Thanks
Post #526927 3rd Sep 2019 8:12am
Brian Considine
Technically, to stay legal the actual plate must be standard size irrespective of the amount of letters.
Please disregard - I stand corrected. 2003 Range Rover Vogue TD6
Post #526933 3rd Sep 2019 10:02am
Full Fattie
It should be but I’m happy to accept the risk
Post #526935 3rd Sep 2019 10:05am
Weegie
... John
GAP iiD BT
Post #526936 3rd Sep 2019 10:09am
As far as I know there is no size stipulated for number plate dimensions.
What is specified is the letter size and spacing to the correct font and an 11mm minimum border around all letters, top, sides and bottom.
Therefore the number plate height is determined by the font height plus 22mm for the margins.
Similarly the length is determined by the font width plus spacing between the letters plus 22mm for the margins.
Therefore a private plate with only a few letters only needs to have letters the correct size and font and correct spacing plus 22mm for the borders.
The less digits, the shorter the plate can be.
Surprisingly there is no limits to the size of plates you can have, presumably this is why oversized rear number plate are ok on Range Rovers.
I stand to be corrected of course if someone knows better Thumbs Up
Post #526937 3rd Sep 2019 11:03am
^ sounds about right...
heres an pic of cam-tec-craigs old L322,
Post #526938 3rd Sep 2019 11:14am
Full Fattie
id Read conflicting things about the size but Stan that makes sense.
Craig, do you remember the size, number of characters and how you secured it to the boot?
Post #526946 3rd Sep 2019 12:01pm
Brian Considine
Unnecessary quote removed
I stand corrected on the size of the plate as long as it has the correct sized margins/letter spacing & so on.
AFAIK, plates had to be a minimum size at one time but it seems to have changed.
Imported vehicles that are not EU type approved do have some "wriggle room" regarding smaller plates. 2003 Range Rover Vogue TD6
Post #526955 3rd Sep 2019 1:14pm
MisterT
United Kingdom 2011 Range Rover Autobiography TDV8 Baltic Blue
Here’s a pic of the tailgate recess behind the plate, didn’t measure it maybe you can judge size from photo....
Post #526968 3rd Sep 2019 4:03pm
the recess isnt very big so a small plate will cover that.. ... - .- -.
Post #526970 3rd Sep 2019 4:32pm
Full Fattie
That’s much smaller than I feared so should be fine. Now I have the unenviable job of removing the glue from the sticky strips. I used a lot cause I didn’t want to screw it on
Post #526994 3rd Sep 2019 9:02pm
MisterT
I used a hairdryer to soften the glue and most of the strips peeled away then brake and clutch cleaner to remove the adhesive residue
Post #526998 3rd Sep 2019 9:41pm
My plates are 13" x 4.5" instead of the standard rear plate which is 20.5" x 4.5"... My reg no is 4 digits long and was fitted using standard numberplate screws... Thumbs Up
Post #527000 3rd Sep 2019 9:56pm
