Home > Technical (L322) > Big bang to find 3mm wide crack in the Expansion bottle
green-oval-nut
United Kingdom 2005 Range Rover Vogue Td6 Stornoway Grey
Hi, my friend has a 2003 4.4 Petrol Range Rover L322 (M62) BMW Engine.
I received a call the night before last to say he heard a loud bang and then steam coming from under the bonnet.
Upon investigating, we found a 3mm wide (roughly) crack down the back left corner from under the lip down to the bottom.
Any ideas what would have caused this please? My 02 V8's went in February this year, but I didn't get a loud bang and you still couldn't see the split in mine after it went.
Cheers.
Post #525325 19th Aug 2019 12:03am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
I believe its quite common on the V8`s as the pressure is quite high. Use a TD6 cap which is 140kpa. The V8 is 200kpa 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #525337 19th Aug 2019 7:48am
green-oval-nut
Cheers, was just worried that there may have been another reason to the severity of this break. I will be on changing this tonight.
Post #525366 19th Aug 2019 10:24am
