Home > Technical (L322) > Play in supercharger
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
How much, if any, backlash is acceptable at the supercharger pulley? If I turn mine back and forth there is a few mm play before you can feel it engaging.
Post #521021 7th Jul 2019 9:51pm
kezbo1981
I have uploaded a video of the play. I'm assuming this isn't normal.
Post #521249 9th Jul 2019 5:57pm
friskydog
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I have just been told that the coupler on mine has gone and that it had play where you are showing. I have also been told that I cant just detach the snout/nose to repair. You appear to need to take the whole supercharger off which sounds a big job.
I am planning on doing a complete supercharger rebuild due to this as I have done 107,000 miles now. This will mean oil, bearing, coupler change with a new 10% smaller pulley to improve supercharger engagement at lower rpm which seems an historic problem according to the forums. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #521380 10th Jul 2019 5:56pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
getting the supercharger off it quite simple, does involce a lot of steps but is quite easy, i didnt even need to put the bonnet in the work position to do it.
you will need to drain out the system of water though as this give you alot more flexibility in getting at some bits.
mine also has about the same amount of play on the pulley, i cant see any oil in my super charger unit any where? (4.2 jag)
will keep an eye on this one.
also where do you get the smaller pulley from?
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #521565 12th Jul 2019 11:22am
kezbo1981
Yesterday I bought a bearing kit, solid isolator and 10% smaller pulley from Powerhouse-uk's ebay shop. I'm hoping to pull the supercharger off next week and do the work.
Post #521574 12th Jul 2019 1:46pm
friskydog
My pulley play is similar to the one in the video above and it's not normal according to the guy that took my supercharger out in less than 30 mins today. I also need a new throttle housing gasket. I noticed inside the supercharger that the rotors are slightly marked. So a service seems a definite as soon as any sound is heard. My noise was on startup and wasn't regular. So any noise from below the pulley get it checked straight away it's probably the couplar. I will update you when my charger is serviced.
Post #521610 12th Jul 2019 8:33pm
MattHughes86
aaa that looks so familiar...
i might look at getting mine serviced as mine is similar to yours with light markings on the veins.
where are you getting your serviced at?
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #521635 13th Jul 2019 8:28am
friskydog
I am getting mine picked up by Powerhouse UK Chesterfield on Monday so will soon have her back together. Checked the hoses under the supercharger and all seems well thankfully although throttle body gasket needs replacing. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #521668 13th Jul 2019 6:23pm
kezbo1981
Managed to get mine out yesterday.
Post #522076 18th Jul 2019 7:54am
MattHughes86
glad to know im not the only one doing this sort of work.
once your super charger has been serviced can you let me know what sort of cost it was please?
just so i know how much longer mine (the wifes) car will be off the road
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #522146 19th Jul 2019 7:53am
kezbo1981
I'm changing the bearings myself as I have a press. I bought a kit containing the snout bearings, rear roller bearings, oil and a solid coupler from Powerhouse UK and it was around £170. Ive got it all apart now - you need a press to DIY - and the bearings were all fine, just the coupler that was knackered.
Post #522148 19th Jul 2019 8:26am
MattHughes86
have you got any photos?
have a press at work where im doing all of my tinkering
Previous Vehicles:
1.9TD Seat Toledo
1.4 Seat Ibiza
Post #522149 19th Jul 2019 8:32am
kezbo1981
Ive been meaning to take some. I watched two really useful videos on youtube which tells you all you need to know about the snout bearings:
These are a M90 snout, but they are essentially the same as the M112. They dont show removal of the pulley, but I used the press for that too after heating it with a blow torch - that was the hardest part to remove.
Post #522150 19th Jul 2019 8:44am
friskydog
So I have my Supercharger back.
The rebuild cost £350
Upgrade 10% reduced pulley size at end of snout £300
I thought the whole thing was £350 but not so when I received the bill. Unfortunately it was my own fault for not checking.
The Supercharger feels alot better. I havent properly opened her up yet. But I definately hear the whine alot more consistently than before. Smile Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #524844 14th Aug 2019 7:59pm
Danwilderspin
Hi guys,
I have a leak from one of the cooler lower gaskets (driver side)
To change this I need the charger out to access the bolts. How much of the cooling system can I get away with leaving? do I have to take the whole metal thermostat housing off the front?
Cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #534237 14th Nov 2019 2:55pm
